29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Hiding A Beam System
I have a attic framing plan that is showing roof rafters (which come down to the same elevation as the attic joists) that I don't want to be visible. These rafters are modeled through a beam framing system. I would like to hide these roof rafters within this view. In general, is it possible to hide a particular beam system within a view, while keeping other beam systems visible?
Normally when I want to hide an object I'll type in "EH" and click on it, which makes it disappear from view. But when I try to hide a beam system with this method it doesn't hide the rafters, instead it takes away my ability to select the beam system while leaving it fully visible.
I could select the beam system and click "remove beam system" to make the rafters individual objects, and then hide each one, but I frequently need to modify the boundaries/slope of the rafters, which will make this problematic for future changes. Any ideas?
Thanks!
Structural beam system visibilty |
Mon, Jan 28, 2008 at 6:08:26 PM
Beam system height VS. Beam height error |
Fri, Jan 22, 2016 at 4:31:20 PM
Adding a beam system issue |
Sun, Jun 15, 2014 at 2:58:10 PM
Beam System Tag |
Fri, Aug 14, 2009 at 3:09:33 AM
Schdule of Beam System |
Tue, Jan 4, 2011 at 5:45:12 AM
