Forums >> Revit Systems >> Technical Support >> Transferring Legends From One Project To Another
Wed, May 7, 2014 at 9:37:26 AM | Transferring Legends From One Project To Another
cdhackett
I am trying to transfer two legends from one project to another; however, the copy to clipboard is greyed out.  I also tried to transfer project standards and that did not work as well.  There has to be a way to get legends created in one project into another project.
Wed, May 7, 2014 at 9:50:15 AM | Transferring Legends From One Project To Another
Insert from file....
Wed, May 7, 2014 at 9:51:52 AM | Transferring Legends From One Project To Another
cdhackett
How if you click on the legend and try to save to file its greyed out as well.
Wed, May 7, 2014 at 10:15:28 AM | Transferring Legends From One Project To Another
You don't understand the process.  The Help explains it.
  1. From the file where you want the legend. - Click on Insert Tab / insert from file
  2. Pick the file with your legend
  3. Pick the legend & finish.
Wed, May 7, 2014 at 10:39:20 AM | Transferring Legends From One Project To Another
cdhackett
Thank you for the suggestion but that does not work either.  Only sheets, schedules, and drafting views show up.  Legends is not in the list and even the sheet that has the legend on it is not in the list.   It omit its for some reason.  Cannot believe revit doesn't have a simple way of transferring legends.
Wed, May 7, 2014 at 12:13:03 PM | Transferring Legends From One Project To Another
It does work, it has always worked - except for those internals.
Fri, May 9, 2014 at 4:52:47 PM | Transferring Legends From One Project To Another
cdhackett
Well it doesn't work for me.  I am using Revit 2014. I have attached what it gives me when I go through the steps you gave me.  I am chooseing a job that has two legends in it but it still doesn't show up.
Mon, May 12, 2014 at 8:07:50 AM | Transferring Legends From One Project To Another
Just edit the existing legend - window and copy to clipboard and paste in a new legend in your new project.
Fri, Dec 22, 2017 at 2:45:17 PM | Transferring Legends From One Project To Another
Prophecy99
Prophecy99 Avatar
legends are not avail in the pick down list when inserting from file ! any updates on this?
Imagination reveals truths reality obscures.
Fri, Dec 22, 2017 at 2:56:17 PM | Transferring Legends From One Project To Another
Prophecy99
Prophecy99 Avatar
as a quick alternative or direct approach, i just copied clip board the elements in the legend view i needed to copy and then just pasted it in new views created in the project being pasted into
Thu, Oct 23, 2025 at 6:18:54 PM | Transferring Legends From One Project To Another
#11
bernardi
Actually Py Revit does this transfer. Even with objects overrides (copy and paste doesn't preserv it)
Fri, Oct 24, 2025 at 6:47:30 AM | Transferring Legends From One Project To Another
#12
Ferece
Great concept! Transferring legends between projects can really streamline workflow and keep designs consistent. I’ve used [url=https://www.beautyplus.com/object-remover/remove-people-from-photo]BeautyPlus[/url]  for similar creative edits—it makes the process even smoother!
Transferring from project 2 project, and one family Q
Thu, Jul 24, 2008 at 1:48:07 PM
Legends
Sat, Nov 24, 2007 at 12:14:00 PM
Revit 2015 - Transferring Project Units and Mechanical Settings
Thu, Jan 7, 2016 at 8:12:07 PM
JORGE782
Tue, Jun 14, 2005 at 12:37:09 AM
Adding / Aligning Legends to multiple sheets
Fri, Oct 17, 2014 at 9:03:43 AM
Page generation time: 1.1068
