14 Users Online (12 Members):
Forums >> Revit Systems >> Technical Support >> revit roof slopes
0 Posts No Rating |
Hi all,
so it's first time I use Revit as BIM for the entire project.
I'm doing the roof slopes and when I place the drains, hosted in the light concrete slopes, not in the slab below; they don't show in the roof level, slopes are, drains aren't; so I can't tag them etc. I see them in the 3D and sections. It's driving me nuts!
Thanks,
We don't know enough about your components and process. Here are some suggestions:
- Check what family category your drain is and make sure that is on in the view.
- You say the drain is heted in the light concrete. Does that mean there is another surface above that? Perhaps your drain does not cut that.
- If you are using design options or phases, you will have to look at these as well.
Adding skylights and slopes to a roof |
Thu, Jul 12, 2012 at 8:33:07 AM
roof issue (even roof valley slopes with uncentered drain locations) |
Wed, Mar 14, 2012 at 12:25:14 PM
Roof Slopes |
Fri, Sep 24, 2004 at 11:17:08 AM
13
roof slopes with skylight openings and notch |
Wed, Apr 21, 2010 at 1:09:29 PM
11
compound slab or roof slopes |
Wed, May 27, 2009 at 7:19:30 AM
