Forums >> Revit Building >> Technical Support >> Can't see first storey walls in first storey plan view
Mon, May 5, 2014 at 2:00:07 AM | Can't see first storey walls in first storey plan view
ljtaylor88
I drew a series of walls in the 1st storey plan view: the base constraint is the 1st storey, the top constraint 2nd. No offset.Did the same for 2nd storey walls in 2nd storey plan view, with corresponding base/top constraints. You can see the 1st storey walls as an underlay in 2nd storey view, as is standard.
Changed my View Range in 1st storey plan view because I could also see my 2nd storey walls in that view. This also took away my 1st storey walls. But I can see them as an underlay in 2nd storey plan view. Been fiddling with the View Range for 1st storey plan view, no changes.
Where am I going wrong here?!
Mon, May 5, 2014 at 9:02:22 PM | Can't see first storey walls in first storey plan view
ljtaylor88
Solved : finally got the right View Range settings.
Unconnected first and second storey walls moving together, screwing things up
Fri, Feb 25, 2011 at 6:27:42 AM
moving part of a 2 storey building
Wed, Jul 1, 2015 at 12:38:31 PM
MUlti storey floor plan view sheet alignment
Wed, Jul 19, 2006 at 1:34:05 PM
Examples of drawings for 2 storey extension
Thu, May 20, 2010 at 12:45:35 PM
Floor Plan View Range - Viewing a half storey
Thu, Jul 12, 2007 at 3:32:23 PM
Page generation time: 1.3784
