Forums >> Revit Building >> Technical Support >> Graphics card causing crash
Fri, May 2, 2014 at 2:31:01 PM | Graphics card causing crash
Pikachu123
would anyone happen to know anything about a update, or something regarding hardware would cause revit 14 to crash, and windows to give a graphics card failure warning from the taskbar. and being able to get into revit menu screen, but as soon as you try and open anything the openning window goes away, and you waet a "older" looking warning window preventing you from going any further, but give it about ten mins, and you can open anything and keep on trucking. very strange. any sugestions?
Fri, May 2, 2014 at 10:22:33 PM | Graphics card causing crash
StriickeN
StriickeN Avatar
What is the model of your graphics card?
Mon, May 5, 2014 at 8:44:16 AM | Graphics card causing crash
Pikachu123
5800x quardo VERSION 335.23
Mon, May 5, 2014 at 4:25:43 PM | Graphics card causing crash
StriickeN
StriickeN Avatar
I guess I wasn't thinking when I asked that. I meant to ask what Windows version you were using (I'll assume windows 7 or 8/8.1 for this) and if it's a laptop or a desktop (I'll assume it's a desktop). There can be many reasons this is happening, that GPU/graphics card is more than enough to run Revit so it can't be a specification issue. I would say it is one of the following that is causing this:
- The PCIe slot on the motherboard is defective ~ You can troubleshoot this by trying the graphics card in another system and seeing if the problem persists. If you don’t have another system I would at least take out the graphics card and clean out the PCIe slot as much as possible as there might be something inside it that is blocking its communication with the motherboard.
- A recent driver update is interfering with the GPU's compatibility with the program ~ Have there been any recent updates from Nvidia that were installed? Also if you haven’t updated in a while it usually helps to fully un-install your current drivers and install the newest ones from Nvidia.
- The GPU is overheating ~ Less likely but still possible as you mentioned waiting ten minutes fixes it. If you can, make sure the heatsink on the graphics card is free of any dust and there is nothing blocking the fan plus it is working properly.
- The GPU isn't strong enough to handle Revit (of course it is)
If none of these work let me know and I can try my best to help you get this fixed and working.
Tue, May 6, 2014 at 3:35:39 AM | Graphics card causing crash
archigrafix
5 Stars: 4 Votes
We have experienced crashes with Quadro FX 3800 /Win 7 + revit 2014 Update2 and were promissed by the department that tests cards at Autodesk that an Revit 2014 update would include our card in the certified list. However that did not happen and it also does not solve the problem. What seemed to have helped was to update the graphic card drivers to the latest version - since that revit / the graphic card driver has not been crashing.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Tue, May 6, 2014 at 12:31:00 PM | Graphics card causing crash
Pikachu123
Thank you the input, i'm working with our IT guy to find a certified card, that is also copesetic with our other program we run. Thanks guys.
lumion graphics card use
Tue, Dec 2, 2014 at 2:03:22 AM
Revit crash when dimensioning
Thu, Jul 15, 2010 at 7:38:36 AM
11
7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
Wed, May 7, 2008 at 11:34:38 PM
Materials causing revit to crash
Wed, Jan 31, 2007 at 1:38:54 PM
Revit graphics card?
Thu, Feb 20, 2014 at 12:47:10 PM
Page generation time: 0.4908
