Forums >> Workflow & Implementation >> API & Third Party Apps >> access Appearance properties of materials
Thu, May 1, 2014 at 4:02:40 PM | access Appearance properties of materials
kukuzry
My purpose is to access the all material properties, in all tab (e.g., graphic, appearance, thermal, physics)
From the material class, to access appearance properites, I use the following code:
Document doc = m_material.Document;AppearanceAssetElement aae = doc.GetElement(m_material.AppearanceAssetId) as AppearanceAssetElement;
However, how can I get the appearance properties, the AppearanceAssetElement does not have properties for such as "tint" "cutout"
How can I get accesss all the properties of materials through API?
Here is an image: iamge
When editing materials through properties, only two show up??
Tue, Mar 13, 2012 at 3:38:21 PM
adding more appearance properties options?
Wed, Apr 17, 2013 at 1:20:21 PM
Adding New Materials to the Render Appearance Library in RAC 2009? [ 1 2 3 ]
Fri, Aug 8, 2008 at 6:11:21 PM
31
Appearance Property Set default
Mon, Mar 5, 2012 at 3:00:19 PM
Revit's Mental Ray issues
Mon, Jul 21, 2008 at 6:37:57 AM
Page generation time: 1.3198
