Forums >> Revit Building >> Technical Support >> Lost Work (model has reverted back)
Thu, May 1, 2014 at 2:26:18 PM | Lost Work (model has reverted back)
mfadel20
This has happened to me on several occassions...I will have completed tasks in the model only to come back several days later and find that they have reverted back to an earlier version of the model where that work has disappeared.  The program (2013) doesn't crash and the other few people in the office seem to be using worksets in the (semi-)appropriate way.  And it's not like the whole model has gone back to an earlier version...just select parts.
Since we have relatively few people working on a project at once, we do not bother breaking elements out onto specific worksets, but rather folks borrow elements until they are relinquished during a synch.
Trying to diagnose the problem and believing that it could have been an issue with people in the office using (and synching) an older version of the model, such as if they continue to open up their local copy every day rather than creating a new local from the central at the start of the day, I sent the message describing the best practices way of opening/synching and it was clearly understood by my colleagues.
This has happened in everything from schedules to walls to annotation, so it seems to cross the gamut.  Has anyone else experienced this issue and is there a possible fix?  I'm almost to the point of believing in conspiracy theories and that my system is being hacked by Revit Goblins when I'm not looking!  Help.
Thu, May 1, 2014 at 2:37:27 PM | Lost Work (model has reverted back)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Revit doesn't just go back or delete things on its own.  If you have a central file someone may not be using a local file or using an old local file that is screwing up your project.  This is most likely a process problem in your office.
Thu, May 1, 2014 at 2:38:26 PM | Lost Work (model has reverted back)
This is a process problem in your office.  You need to retrain the staff on how to use worksets.  Someone is working in the central or over-writing it.   Syncing an older local with the central will only add CHANGES that user made.  If someone is checking out worksets and working at risk, be careful!
Central Model rolls back to previous version
Thu, Jun 5, 2014 at 7:47:21 AM
Lost Levels
Sat, Mar 18, 2017 at 6:55:00 AM
Model for back to back water closets
Wed, Jul 22, 2009 at 4:32:41 PM
New from Portland, lost my 3d model
Tue, Mar 13, 2012 at 9:34:29 PM
Lost steering wheel 3d tools
Wed, May 14, 2014 at 1:45:27 PM
Page generation time: 1.7196
