Forums >> Revit Building >> Technical Support >> Family Type driven length parameter help
Thu, May 1, 2014 at 2:01:56 PM | Family Type driven length parameter help
kal911
-Revit MEP 2012-
I was trying to create a parameter for a model I'm working on where the length of a dimension changes depending on which nested model is selected from another drop down parameter of family types (generic models)
Basically if Model 1 is selected from a drop down nested Family Type parameter, Dimension A is 3" and if Model 2 is selected from the drop down, Dimension A is 6".
Trying to use the arropriate terms, I'm referring to the Family Type parameter and not the Family Type header that pulls from type catalogs.
Any help or advice would be great.
Thanks.
Thu, May 1, 2014 at 2:23:49 PM | Family Type driven length parameter help
You need a reference plane in the family that you dimension to in the model and that reference plane is controlled by your parameter.
Thu, May 1, 2014 at 3:08:42 PM | Family Type driven length parameter help
kal911
I appreciate the advice. Can you offer any help with the formation of the formula? I've never been able to include a family type parameter In a formula before.
Creating a Beam Family Where Each Type has a Determined Length
Wed, Aug 31, 2016 at 11:55:27 AM
11
Family Instance Parameter Dimension Help
Wed, Apr 10, 2013 at 5:22:09 PM
Can a Yes/No Parameter control a Length Parameter?
Thu, Mar 22, 2012 at 12:17:27 AM
-ve value for a length parameter
Thu, Dec 2, 2010 at 12:14:32 AM
excluding a type in the family type parameter
Thu, Mar 20, 2008 at 3:38:32 AM
Page generation time: 0.8003
