17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> cant get color out of the view
So Ive switched to hidden line or wire frame, the color you see on the screen shot doesnt go away. does anyone know what setting Im missing? looking for the last 20...:-P
thanks in Advance.
Edited on: Thu, May 1, 2014 at 12:49:45 PM
Turn off color fill under rooms and areas?
We don't know what this view really is so we can only guess.
What are those skylight like objects?
Do you have CAD in here?
Edited on: Thu, May 1, 2014 at 12:55:14 PM
Turned off the "visible" in the color schemes submenu, but no go. its a plan view of course, received the model from a consultant, dont know what they did to get the color to show all the time. lots of generic models in this one.
That information is important.... It is a linked model then that shows trough your model, not your stuff?
You need to control their model seperately through VG and do some testing. Turn off all of their annotations then 1/2 of their model categories at a time. If that turns it off then you can narrow your search accordingly. Also then, if needed, turn off their imported items
Its a single project model. there is no linked files. This is our inhouse project. drawn by a consultant, before we had Revit. now we do, Were trying to make it work with our graphic standards.
There are a lot of inplace generic models, but the skylights that are green, are just skylights. in VG turning off windows catagory turns off the skylights like it should.
here I dumbed down a model to show.
Look at the skylight family..... It could have a CAD import, in which case you control the color in the model through VG/imported categories and there could be a color filled region in the family.
Flat color on curved surface, same color on foreground & background |
Wed, Aug 10, 2011 at 7:16:06 PM
Toposurface Fill Color in a Section View |
Fri, Jan 30, 2009 at 9:28:10 AM
change shade color in views |
Tue, May 15, 2007 at 11:40:20 AM
why shading material color gets overridden by surface color |
Wed, Apr 25, 2018 at 9:53:40 AM
**URGENT HELP NEEDED** Graphics Issue With Color Fills |
Mon, May 19, 2014 at 6:44:25 PM
12
