Forums >> Revit Building >> Technical Support >> Not snapping to layer faces inside of wall.
Thu, May 1, 2014 at 12:20:38 PM | Not snapping to layer faces inside of wall.
gcheung1749
Hi there,
I want to snap to the inside faces of the walls in a detail callout, to add in a filled region, but it does not snap.  The layers in the floor snap fine but the layers in the wall section does not.  Is it because the wall section is being cut at an angle, because it is not parallel to the cut plane?
Thanks.
Thu, May 1, 2014 at 12:33:33 PM | Not snapping to layer faces inside of wall.
Yes, you are correct.  You can not align, snap to or dimension to faces that are not parallel or perpindicular to your cut plane.
different Material/Paint/Texture/Finish to inside and outside faces of the wall
Tue, Aug 25, 2009 at 3:57:50 PM
Cutting isolation wall layer with beam inside
Thu, Apr 20, 2017 at 4:12:08 PM
Walls with 2" airs space on inside, whole wall is transparent form insed view?
Wed, Mar 12, 2014 at 3:45:22 PM
Revit Arch 2015 - Wall - Hide a Wall Layer line
Tue, Oct 28, 2014 at 12:30:39 AM
dimensioning a curved wall's faces in section?
Sun, Jan 17, 2016 at 6:59:30 AM
Page generation time: 2.3970
