Forums >> Revit Building >> Technical Support >> importing CAD files into REVIT 2014 (why the walls aren't showing up)
Mon, Apr 28, 2014 at 8:44:01 AM | importing CAD files into REVIT 2014 (why the walls aren't showing up)
agdjdoel
when i received a cad file from an architect, with there layers system and x-refs and all. I usually link that file into my Revit model.
But I always have a problem with the layers not all showing up. Yes, I do get the proxi crap to turn to 1 or 0. but it doesn't matter. there walls never show up.
Why is this happening espeacially since they are both Autodesk products. You would think that they would talk to each other nicely.
What am i missing here that the cad file don't show up completely?
we are both using 2014. I am in Revit 2014 and they are in AutoCAD 2014.
anybody??
Mon, Apr 28, 2014 at 8:52:57 AM | importing CAD files into REVIT 2014 (why the walls aren't showing up)
It could be that you have model elements hiding the import - like floors.  Change your view to wireframe and see if that helps.
Mon, Apr 28, 2014 at 5:53:23 PM | importing CAD files into REVIT 2014 (why the walls aren't showing up)
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Setting the view range to' unlimited' may also help along with wireframe visibility. I'd open the DWG and do some poking around too. Maybe even flatten it.
Wed, Apr 30, 2014 at 4:05:33 PM | importing CAD files into REVIT 2014 (why the walls aren't showing up)
agdjdoel
Thanks
it seem it is a little bit of both.
The flatten command in autocad doesn't work really well.
Importing CAD to REVIT (vs. 2014)
Mon, Nov 24, 2014 at 4:03:43 PM
REVIT'S POOR GRAPHIC DESPLAY WHEN IMPORTING AUTOCAD FILES
Sun, Sep 24, 2006 at 10:37:21 PM
Importing 3D CAD Files
Tue, Apr 23, 2013 at 4:29:30 PM
Importing Cad Files
Tue, Mar 31, 2009 at 8:36:59 AM
import cad to revit - missing layers in revit
Tue, Sep 8, 2015 at 11:11:14 AM
Page generation time: 2.6592
