Forums >> Revit Building >> Technical Support >> Underlay is not working
Sat, Apr 26, 2014 at 6:17:31 PM | Underlay is not working
penzalm
I cannot seem to figure out why my level 2 will not underlay level 1.  The basement level will underlay on level 1, and I can underlay level 2 onto level 1, but nothing shows up on level 2.  The view ranges are not overlapping each other, I have no floors or roofs in the way, and my underlay orientation is set to plan.
Even when I turn off the underlay change the view depth to show level 1, it doesn't show anything...
I have searched for the answer for hours and nothing has worked...
Mon, Apr 28, 2014 at 5:29:50 PM | Underlay is not working
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Post a snapshot of your level 2 view range.
Post a snapshot of a section thru both levels.
How far apart are the levels ?
Is level 1 made up of REVIT walls etc ?
Using linked files ?
Using View a template ?
Try switching to wire frame just to see what happens.
Try making a view template of a a plan view that does behave properly then apply that view template t your level 2 plan view.
Try changing your View Range 'Bottom and View Depth level to 'unlimited'
Underlay Issues
Wed, Mar 29, 2006 at 11:52:24 AM
Where is my underlay?
Fri, Mar 20, 2009 at 11:43:15 AM
Underlay
Thu, Oct 11, 2012 at 8:15:33 AM
Underlay Issue
Fri, Oct 4, 2013 at 11:30:03 AM
Design Option Underlay
Fri, Apr 6, 2007 at 2:06:03 PM
Page generation time: 1.2786
