Forums >> Revit Building >> Technical Support >> finish/ material schedule
Fri, Apr 25, 2014 at 11:00:48 AM | finish/ material schedule
ledgewood33
I am wanting to create a finish schedule that has always been done in CAD. I would like it to reference the MARK/ KEY in the schedule and drawings. I am attaching a PDF of what is done in CAD in the past and is what I would like to replicate.
Fri, Apr 25, 2014 at 11:07:59 AM | finish/ material schedule
So do you want a dumb schedule or a smart one?
This could be smart as a multicategory schedule using the same shared parameters assigned to your model elements.
Obviously, as a dumb schedule, you can just do it in a drafting or legend view as you did in CAD.  Or you can create a schedule key using a category that is not normally used in your project.  You can find threads here about using a schedule key.
Fri, Apr 25, 2014 at 11:17:08 AM | finish/ material schedule
ledgewood33
sorry for not clarifying. also I am using 2013 & 2014.
I would like it to be as smart as possible. meaning that I would like the marks on the schedule to match the tags on the
drawings and the use of any other categories provided.
Fri, Apr 25, 2014 at 12:30:26 PM | finish/ material schedule
Here is a description of using a multi-category schedule:
http://docs.autodesk.com/REVITST/2010/ENU/Revit%20Structure%202010%20Users%20Guide/RST/index.html?url=WS46b90c3cb2c58cad1cb25f1fc7fa49ed4-7fed.htm,topicNumber=d0e17289
NOTE:  You need to create shared parameters and assign those to all elements to be scheduled.  You can assign those as project parameters picking the multiple categories.
Finish Material Schedule
Tue, Nov 29, 2005 at 12:31:59 PM
Schedule material mark in door schedule - Revit 2014
Fri, Jan 19, 2018 at 2:57:03 PM
Revit 2016 Room finish schedule and material schedule
Thu, Mar 9, 2017 at 3:41:41 PM
Key Schedules/Finish schedule
Thu, Jul 8, 2010 at 1:35:21 PM
Finish Schedule
Mon, Aug 10, 2009 at 6:25:50 AM
Page generation time: 1.0229
