Forums >> Revit Building >> Technical Support >> Numerate 'Sheet Number' parameter for match line family
Thu, Apr 24, 2014 at 12:05:31 PM | Numerate 'Sheet Number' parameter for match line family
davidr58
I'm using Revit 2013 and need to know if i can make a formula that uses the Sheet Number category parameter to setup a drawing
number parameter (final sheet number) in my match line family as shown below:
Final Sheet number-- formula I need :  =Sheet Number +1
Revit doesn't seem to let you use cagegory parameters in formulas??  Any suggestions?  I am trying to automate the sheet reference
number in my match line family so I don't have to enter all the sheet number.
Thu, Apr 24, 2014 at 12:17:47 PM | Numerate 'Sheet Number' parameter for match line family
Sorry but I'm lost.  Matchline references should automatically point to the correct view/sheet automatically just like sections, elevations, details.....
So what are you doing?
Thu, Apr 24, 2014 at 12:53:54 PM | Numerate 'Sheet Number' parameter for match line family
davidr58
im not using revits match line im using my own family because we don't like what revits' looks like
Thu, Apr 24, 2014 at 1:34:24 PM | Numerate 'Sheet Number' parameter for match line family
Yes.... We created our own family as well but it is still fully automatic.
Fri, Apr 25, 2014 at 12:14:28 PM | Numerate 'Sheet Number' parameter for match line family
davidr58
Thats sounds great!  Can you share how you did it?
Fri, Apr 25, 2014 at 1:03:44 PM | Numerate 'Sheet Number' parameter for match line family
First you have to understand and use dependent views:
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-EF8CCDA0-9946-49FA-B7AB-2B94470525D2
From the main view, you create your matchline:
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-67176ECE-48EE-4229-BCB5-C4871B99D36B
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-90C3F5C4-6AD4-4AE6-A16D-EF961F4EA789
OK ... so you should have by now created the views and placed your match line.  Set the crop regions in both views so that the parent is one side and the dependent is the other.  To see the process works, place these two views on seperate sheets.  Now open the main view and from the view tag pick "VIEW REFERENCE"  As you place this in the view, you will see it correctly idetifies the location of the dependent view.  After placing, pick the reference then pick edit family from the top menu.  Now change it however you want.
Fri, Apr 25, 2014 at 2:48:23 PM | Numerate 'Sheet Number' parameter for match line family
davidr58
i tried doing what you suggested but when i place the View ref in I only get a "REF" on the tag-I don't think ours is setup correctly yet!
Mon, Apr 28, 2014 at 10:17:51 AM | Numerate 'Sheet Number' parameter for match line family
Sorry but we can't help you anymore without more information.  The process above works.  You can post your reference family if you want but this is so simple.  All you should be changing is possibly the text size and adding graphics.
Sheet 'X' of 'Total Number of Sheets'
Wed, Jun 5, 2013 at 4:39:34 PM
Sheet # of 'total number of sheets'
Fri, Nov 16, 2007 at 6:59:54 AM
View List doesn't have parameter to show them in order of number on sheet?
Fri, Aug 26, 2016 at 2:48:10 PM
Changing paramaters of 'Title with line'
Wed, Sep 20, 2006 at 9:47:18 PM
Printing a set as PDF's
Sun, Sep 24, 2006 at 8:56:03 PM
Page generation time: 2.3283
