33 Users Online (31 Members):
Forums >> General Discussion >> Revit Project Management >> Exporting to PDF results in blank page
Hi, I am a self taught Reviter with less than a year of experience so pardon my ignorance
As the Thread title states, I am recieving a blank PDF file, that is, the page is completely white when I plot to the Adobe PDF printer. I have hardware acceleration turned on as well as anti aliasing in the graphics options.
The steps I take are as follows:
Print > Adobe PDF > Print Range - Visible portion of current window > Print Setup > Paper size - Arch D > Placement - Center > Zoom 100% > Raster - High
Also, my raster views show a blank PDF while Vector floor plans for instance print the linework, but the image is not centered and does not correspond to the scale I specified.
Are you sure you want to print "Visible Portion"? That is a cropped window based on what you are looking at. Perhaps it should be current sheet, or current view. Otherwise make sure you are seeing what you want to print on your screen.
I agree with WWHub. Also might want to check and see what it shows on the "preview" before you print. Odds are if it's showing blank on the preview something is out of whack in your print settings somewhere.
Camera views export blank images |
Mon, Dec 9, 2013 at 2:13:16 PM
Cute PDF not working |
Wed, Feb 8, 2012 at 3:31:23 PM
Black lines printing grayscale in PDF |
Fri, Oct 10, 2014 at 4:46:46 PM
revit to autocad-dwg to pdf |
Mon, Mar 20, 2017 at 3:11:13 AM
11
PDF Alignment Issue |
Thu, Jan 29, 2015 at 8:57:04 PM
