Forums >> Revit Building >> Technical Support >> Revision Schedule not populating
Thu, Apr 24, 2014 at 10:07:07 AM | Revision Schedule not populating
fusse555
I am making a template in which I need to schedule the revision history on the sheet.
I have succesfully made a titleblock that can do this when I am using the OTB templates, but when I use the same titleblock family in my own template the revision schedule doesn't populate.
Is there any settings I might not have turn on/off? I have made the template from scratch.
Thu, Apr 24, 2014 at 10:19:45 AM | Revision Schedule not populating
Did you create any revisions?
Manage tab / sheet issues-revisions
You then have to have a revision somewhere on the sheet or in a view on the sheet.
Edited on: Thu, Apr 24, 2014 at 10:20:29 AM
Thu, Apr 24, 2014 at 11:35:43 AM | Revision Schedule not populating
fusse555
I did, but the revision schedule only populates in the OTB templates.
Thu, Apr 24, 2014 at 12:12:43 PM | Revision Schedule not populating
This sounds like you did not create a correct revision schedule on your titleblock.  Read this:
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-0328A204-D5FB-4149-9D3F-635341D8AAB2
Fri, Apr 25, 2014 at 3:31:50 AM | Revision Schedule not populating
fusse555
I have made my schedule like in this tutorial: http://revit.rayvinly.com/customize-revision-number/
However, it only populates when I use a OTB template, but not the template I have made from scratch.
Fri, Apr 25, 2014 at 7:16:39 AM | Revision Schedule not populating
Read the Help I posted.  What you posted has nothing to do with your titleblock.
Hiding a Revision in the Revision Schedule
Thu, Nov 21, 2013 at 3:04:51 PM
Revision Schedule not updating
Tue, Aug 28, 2012 at 7:59:18 AM
REVISION TAG AND SCHEDULE
Sun, Jul 20, 2014 at 3:09:52 AM
View >> New >> Revision Schedule (GONE!)
Tue, Feb 20, 2007 at 11:48:28 AM
To set up Revision cloud schedule, and add prefix to Revision Number?
Sun, Jul 19, 2020 at 6:35:17 PM
Page generation time: 0.5986
