Forums >> General Discussion >> Revit Project Management >> Problem with a floor slab with Mass
Thu, Apr 24, 2014 at 5:16:53 AM | Problem with a floor slab with Mass
Txabarri
I am having an issue when I try to create the slabs from mass floors.
I get this message when I create the mass floors: "Mass Floors may appear incorrect since the Mass contains mesh and solid geometry." When I use the Floor by face tool all of them are created properly instead of one that is not created eventhough the mass floor exists. Has anyone had the same problem before?
Thankyou
Fri, Apr 25, 2014 at 12:38:46 PM | Problem with a floor slab with Mass
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I'm not exactly sure the question here. REVIT doesn't actually have a slab object to start with. It has floors and foundations which can be used as slabs.
So . . . you created levels within a mass, then converted those to 'mass floors' and and now you want to turn the mass floors into floors.
Not sure when and where the error "Mass contains mesh and solid geometyr" comes into play.
Is thta correct ?
Creating drop panels to the underside of a sloped floor slab
Fri, Feb 12, 2016 at 9:41:01 AM
First floor slab or ground floor ceiling?
Fri, Aug 30, 2013 at 7:41:03 AM
Issue creating mass floor area schedule (mix of families & 'model in place' mass
Thu, Sep 27, 2012 at 7:05:36 AM
Floor Slab Slope
Tue, Jan 30, 2007 at 11:01:08 AM
Conceptual Mass and Objects by Face Workflow Problem
Wed, Sep 5, 2012 at 7:19:24 PM
Page generation time: 0.8457
