27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Revit - Specify Coordinates at Point
I am using command (Specify Coordinates at Point) to relocate my project to a specific set of coordinates - usually if i set one point then all coordinates comes ok, however in one of the project there is difference.
Is it bcoz of angle from project north to true north?
Please advise how to get accurate coordinates as drawings from survey department seems to be correct
Thanks in advance
Now on the implementation stage.... |
Watch this video:
http://www.youtube.com/watch?v=BigvY4LT-RI
Dear WWHUB - Thanks, i got some success.
Now the challenge is that survey drawing is in meter unit. When i link same in new Revit project then coordinates are ok, however not in actual project.
Actual project model was started in MM so dont know the right way to adjust coordinates in that file. I am new for coordinates world so please help
Thanks in advance,
Rams
All units can be set in Revit for project and seperately for annotative elements. Change the units of what you need accordingly.
specify coordinates at a point |
Tue, Oct 4, 2005 at 12:56:17 AM
Survey Point and UTM coordinates |
Mon, Jun 20, 2016 at 3:50:02 PM
Shared Coordinates Published Incorrectly |
Mon, Jan 11, 2016 at 6:44:07 PM
Project Base Point |
Thu, Jul 2, 2009 at 6:24:59 AM
Aquiring Coordinates |
Wed, Feb 10, 2010 at 10:22:37 AM
