Forums >> General Discussion >> Revit Project Management >> Downloaded item into Revit
Sun, Apr 20, 2014 at 3:23:37 AM | Downloaded item into Revit
alkin
Do I've downloaded something from this website and I can open it up as a Revit file or load it as a family. After I load it as a family in the file that I am working on, how do I place it in my project?
Also does anyone have experience with curtain walls? I can't seem to get this storefront to work around my concrete floors.
http://imageshack.com/a/img841/1974/rm1w.jpg
It does not attach to my roof floor.
Mon, Apr 21, 2014 at 7:24:20 AM | Downloaded item into Revit
We don't know what the family is....that might have been good to list don't you think?
I think you need to spend time with some Revit tutorials.  Revit elements can  be hosted and depending on the host, you need to be in the correct view to place those.  System elements often require that you are using the proper system menu.
Storefronts won't work around floors in real life or Revit.  You need to do that.
Mon, Apr 21, 2014 at 7:58:17 AM | Downloaded item into Revit
alkin
http://www.revitcity.com/downloads.php?action=view&object_id=9266
Mon, Apr 21, 2014 at 8:41:03 AM | Downloaded item into Revit
If you had opened that family, you would see that it is furniture systems and level hosted.  Open a plan, turn on furniture systems in VG and place the family.
Downloaded an item but I cannot find it in my families - how can I search for it
Thu, Oct 6, 2011 at 5:21:00 AM
Revit LT Select an Item
Fri, Dec 13, 2013 at 9:17:51 PM
Changing colour for revit family downloaded from revitcity
Fri, Nov 6, 2015 at 9:44:53 AM
Can't Place Recently Downloaded Windows from Revit City: Revit Architecture 2008
Wed, Jun 23, 2010 at 3:49:20 PM
ROTATE DRAFTING PATTERN WITHIN DETAIL ITEM
Thu, Nov 2, 2017 at 8:03:01 AM
Page generation time: 5.2161
