28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> TOPO scaling help....need help asap
1 Posts No Rating |
Ive been trying to load a cad topo file into revit...and ive goten it to load (ive tried both import cad origin to origin and link cad)....however the topo loads up ALOT smaller then it should, about 10 times smaller...is there any way to make the topo itself bigger? ive tried scaleing but that doesnt seem to work
THANK YOU!
1 Posts No Rating |
here is the topo file...it seems like it is in 3d already
Change the units that you use when importing.
1 Posts No Rating |
Thank you so much!
now im running into another problem....i have imported the topo, made a revit topo from instane over it, hidden the original cad file...but i can only see the topo in 3d view...i cant find it in level 1 or site
thanks again!
It is probably outside of your view range.. Go to an elevation and you will see where it is in relationship to our first floor level
topo survey AutoCAD to Revit |
Thu, Feb 26, 2009 at 11:45:41 AM
Airport ASAP |
Thu, Feb 14, 2008 at 3:35:58 PM
NEED HELP ASAP ON CEILING! |
Thu, Apr 26, 2007 at 5:18:14 PM
TOPO and Site Planning |
Tue, Oct 30, 2007 at 7:10:48 AM
Topo Lines part 2 |
Tue, Feb 28, 2012 at 10:05:01 PM
