Forums >> Revit Building >> Technical Support >> Adding Material to Divided Surface
Thu, Apr 17, 2014 at 9:48:38 AM | Adding Material to Divided Surface
Jthelen
I am trying to model a wire mesh screen, and the easiest way is to make a mass and divide the surface using the rectangle patter. However, I can't seem to apply a material to that surface once its divided, either with a parameter or with paint.
Thu, Apr 17, 2014 at 10:40:12 AM | Adding Material to Divided Surface
I believe you need to add the material to your generic model pattern based family that you will be using.
Read all of the HELP's sections on patterened surfaces.
Edited on: Thu, Apr 17, 2014 at 10:43:27 AM
Question about modify divided surface
Tue, Mar 30, 2010 at 7:03:39 AM
Parametric Curtain wall panel in divided surface
Sun, Jan 31, 2010 at 8:08:54 AM
Void Mass Not Cutting Divided Surface Mass
Wed, Jan 31, 2018 at 10:19:21 AM
Void surface on divided surface
Mon, Mar 10, 2014 at 5:41:07 PM
How to cut mass conceptual divided surface
Mon, Apr 30, 2018 at 9:15:59 AM
Page generation time: 0.2727
