Forums >> Revit Systems >> Technical Support >> view error revit 2009
Thu, Apr 17, 2014 at 8:15:21 AM | view error revit 2009
Piyush
1. when i draw wall in level 1 it visible in level 1 but not visible in 3d view & vice versa.
2. if i delete the wall from 3d view but also it shows in all orther windows like level 1, level 2, elevations etc then i have
   to delete those wall in every window.
3. railing also shows in level 1 but not in level 2 or 3d view.
Thu, Apr 17, 2014 at 8:20:25 AM | view error revit 2009
From what you have written, it soundfs like your process is incorrect.
Revit walls are 3D and will show up in all views with the correct view settings and view range.  If you delete the wall in any view, it will be deleted in all other views where it is shown.
So - without any other information from you, we can't say much more.  Except, find some beginning tutorials on-line and watch the process of how you add walls and project setup.
revit 2009 error message
Fri, Sep 3, 2010 at 8:23:07 AM
error message prevents upgrade to revit 2009**
Wed, Jul 23, 2008 at 9:04:28 AM
Revit 2010 and Revit 2009 families error
Mon, Sep 21, 2009 at 1:35:48 PM
A serious error has occurred. It is strongly recommended that you use Save As to
Fri, Oct 3, 2008 at 7:52:58 AM
Error Converting Dependent View to Independent View RAC 2009
Fri, Oct 3, 2008 at 8:53:23 AM
Page generation time: 1.9298
