Forums >> Revit Building >> Technical Support >> Creating Lighting fixtures for SEEK in Revit MEP or Architecture?
Wed, Apr 16, 2014 at 7:04:35 PM | Creating Lighting fixtures for SEEK in Revit MEP or Architecture?
hgrimberg
I am about to create lighting fixture families and post them on Autodesk SEEK. Should I use Revit MEP or Revit Architecture?
The SEEK Guidelines recommend to use the older possible Revit version. I've seen many on SEEK that are in 2011 format. Is there a particular reason for that, or doing them in 2010 or even 2009 is the same, or better?
Wed, Apr 16, 2014 at 11:38:23 PM | Creating Lighting fixtures for SEEK in Revit MEP or Architecture?
mansell5
3.5 Stars: 4 Votes
as revit isnt yet backward compatible to users.
the earlier the version used to create families, the more folks can open them.
maybe 1 day autodesk will be able to do what archicad does.
make files openable by earlier versions.
the line that autodesk puts all its development effort into upgrades and new features rather than making later versions compatible with earlier formats seems a bit odd based on the latest release.
where are they?
datacad introduced wiggly lines in 1985.
regards
geoff
What Revit version to use when creating families for SEEK?
Thu, Apr 17, 2014 at 9:37:02 AM
Revit MEP 2010 copy/paste lighting fixtures
Sun, Feb 16, 2014 at 12:46:34 AM
lighting fixtures
Fri, Jul 26, 2013 at 9:45:43 AM
Copy/Monitor - Lighting Fixtures
Thu, Dec 15, 2011 at 4:27:11 PM
Lighting fixture problems
Wed, May 10, 2017 at 9:52:09 AM
13
Page generation time: 2.3194
