Forums >> Revit Building >> Technical Support >> Making Angled or canted walls
Mon, Feb 27, 2006 at 1:40:48 PM | Making Angled or canted walls
kingsley
Hi I am a student who has just started working with revit 8 and I am trying to Put in a wall that is angled angled. How do you do this?Not a very good drawing but i want to look something like the front of this.
Mon, Feb 27, 2006 at 5:27:54 PM | RE: Making Angled or canted walls
arccodex1
3 Stars: 1 Votes
If you go to your tools palette (Basics, View, Modelling, etc) right click on it you'll notice there are massing tools. Create a mass of the volume you want and then use the Wall By Face tool to create walls out of your mass volume.
Tue, Feb 28, 2006 at 4:23:41 AM | RE: Making Angled or canted walls
eldados
eldados Avatar
4.5 Stars: 8 Votes
like arccodex said, a mass is the best option, though you could also do it an an in place wall family using blend... what ever easier Smile
Integrator
KarelCAD
Tue, Oct 16, 2007 at 2:22:07 PM | Making Angled or canted walls
JHanby
3.5 Stars: 3 Votes
I have made an angled mass but want to put windows into the wall. I used the wall by face however I can't put any windows into the wall or even cut an opening into the wall.  How do I go about putting windows into an angled wall?  Using 9.1.
Tue, Oct 16, 2007 at 5:57:32 PM | Making Angled or canted walls
eldados
eldados Avatar
4.5 Stars: 8 Votes
using the opening by face tool, cut the opening you need.
in the opening, create another mass family (go to section and use extrusion)
once you have the mass, do a curtain system by face and edit it with mullions to the window you want
Integrator
KarelCAD
Tue, Jun 3, 2008 at 2:10:07 PM | Making Angled or canted walls
dwendt
how do you cut out the middle part of this condition, I have put it in as a glass wall, just like what is said above (massing) but now i can figure out how to cut out for the door!   The storefront is canted out.  any help? some step by step directions would be greatly appreciated.  maybe with from the beginning to make sure i have constructed it right.  currently the mullions follow the cant, is that a new family i have to make so they are flush with floor and wall?  please help!  thanks
Canted walls
Mon, Jan 19, 2004 at 2:02:17 PM
Angled Walls in Revit
Mon, Jan 12, 2015 at 8:48:26 AM
Revit 2011-putting openings in angled walls.
Sat, Sep 10, 2011 at 5:45:27 AM
How do you make a canted or leaning curtainwall?
Wed, Jul 21, 2010 at 8:07:26 PM
lots of angled window ingoes
Fri, Jul 23, 2010 at 5:52:56 PM
Page generation time: 1.3047
