Forums >> Revit Building >> Technical Support >> ceiling hatch pattern
Wed, Apr 16, 2014 at 6:59:01 PM | ceiling hatch pattern
newk
Hi,
I am using Revit 2014.
When I create a new ceiling & choose the material & pattern I cannot see the ceiling in the ceiling plan as the 'hatch pattern'
is not visible. How do I make it visible?
James
Thu, Apr 17, 2014 at 6:59:10 AM | ceiling hatch pattern
Some new users often incorrectly make ceiling plans from floor plans instead of do a reflected ceiling plan.  If that is the case then you wont see any pattern.
Is a pattern actually asigned to the ceiling material?
Is the material assigned to the proper ceiling layer?
In VG, is the ceiling pattern set to show?
Hatch Pattern in GYP ceiling won't show
Thu, Mar 12, 2009 at 10:00:42 AM
14
I need a simple hatch pattern for a waffle ceiling
Fri, Jan 18, 2008 at 12:53:44 AM
hatch pattern in material anomolies
Fri, Aug 26, 2016 at 9:35:26 AM
invisible ceiling pattern
Mon, Oct 17, 2011 at 7:20:11 AM
Hatch Pattern Request
Thu, May 31, 2012 at 1:19:48 PM
Page generation time: 2.5824
