25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Flexible Stair Riser?
I want to create a custom stair tread and riser profile for a stair shaft assembly spanning 11 stories. I want the riser to have a 1/4" reveal where the riser meets the tread below it, similar to the attached image. The problem is that the floor-to-floor heights vary at times, thus the riser heights also vary floor-to-floor.
Is there a way to create a riser (or nosing) profile that "flexes" with the actual riser height so that the reveal size is consistent? Or will I have to make separate riser profiles for each different riser height?
I'm using Revit 2014 with Update Release 1.
It would be very useful to know this. I'm looking at a similar problem that this would solve.
in the section view make some callouts referencing each different riser condition.
then place on a sheet the different conditions details the various callouts refer back to, perhaps side by side etc so easy to find etc.
PRECAST STAIR BEGIN WITH RISER LOOKS INCORRECT ON PLAN |
Fri, Sep 2, 2016 at 7:03:03 AM
Stair riser - custom |
Tue, Jan 14, 2020 at 5:55:29 PM
Custom Stair Riser Height |
Wed, May 27, 2009 at 10:00:38 AM
Stair riser at floor connection |
Tue, Jul 31, 2007 at 11:51:27 AM
Stair - end riser flush with stringer |
Tue, Mar 3, 2009 at 5:57:58 AM
