Forums >> Revit Building >> Technical Support >> How can I calculate the area of a curtain system
Wed, Apr 16, 2014 at 3:02:17 AM | How can I calculate the area of a curtain system
revitnai
Since the curtain system doesn't have a area parameter embedded which makes harder the make the calculation. Is there any workaround for that?
Wed, Apr 16, 2014 at 7:28:12 AM | How can I calculate the area of a curtain system
Curtain walls are walls.  The area is there for the overall.
You can also take off curtain panels as a material and they have areas.
Curtain mullions can be scheduled by type and length.
Wed, Apr 16, 2014 at 7:29:38 AM | How can I calculate the area of a curtain system
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I get an area when I draw a curtain wall, see attached image
Wed, Apr 16, 2014 at 8:25:01 AM | How can I calculate the area of a curtain system
revitnai
Curtain system and curtain walls are not the same thing. I want to get the whole area of the curtain system inclusive mullion and panels
Wed, Apr 16, 2014 at 9:16:51 AM | How can I calculate the area of a curtain system
What?   Curtain walls are the whole curtain system!
Wed, Apr 16, 2014 at 9:27:24 AM | How can I calculate the area of a curtain system
If you had meant curtain systems created by model by face, you should have said so.  These panels can still be taken off by material and you can total the area and that will be correct if your panels go to the center of the mullions.
Thu, Oct 30, 2014 at 3:42:33 AM | How can I calculate the area of a curtain system
tintin85
i know this is a little late adding to the thread but, regarding getting the area of a curtain system (and yes one applied to a mass face) you mention using a material take off. my question is if you use the material take off for the panels, would this not count the material on the four sides of the panel rather than just the outside surface area? (which is what i would be looking for)
Thu, Oct 30, 2014 at 9:09:51 AM | How can I calculate the area of a curtain system
You are correct.... but you can account for this ...or get very close.
Obviously, if the unit is flat and you wanted total area, a simple filled region would be far easier and quicker.
Thu, Oct 30, 2014 at 9:14:19 AM | How can I calculate the area of a curtain system
tintin85
WWHUB, thanks for the info but unfortunatly the curtain system is on a curved cone shape surface.
would you possible be able to explain how you would account for the 6 sides of a curatin panel?
your help would be greatly appreciated.
Thu, Oct 30, 2014 at 9:17:00 AM | How can I calculate the area of a curtain system
Very-very thin panel for take off and divide by 2.
Scheduling "System" Curtain Walling Panel Parameters
Thu, Aug 28, 2014 at 9:35:36 AM
Filtering curtain panel schedule by type
Mon, Nov 4, 2013 at 9:10:40 AM
Curved Curtain Walls, Patterns, and Area Calculations
Mon, Feb 4, 2013 at 8:15:14 PM
Curtain wall area in window schedule
Tue, Jan 27, 2009 at 10:41:42 AM
How to quickly calculate area like in autocad?
Fri, Dec 3, 2010 at 10:50:04 AM
Page generation time: 0.2890
