Forums >> Workflow & Implementation >> Hardware >> Graphic Cards Issue_Extra lines or materials gone transparent in 3D views
Tue, Apr 15, 2014 at 7:15:56 PM | Graphic Cards Issue_Extra lines or materials gone transparent in 3D views
pompei1009
As you can see from the attached image, the timber floor behind the steel beam should't be shown while the wall cladding material (curtain wall) should have block the wall behind (shown in dark grey). Whenever I move my view around, the graphic errors will occur in different areas.
I am aware that my graphic card AMD Radeon HD 6450 might not be compatible with Revit 2014. Is this a common issue? How can I fix it without having to change my graphic card.
My pc specsPuh
DELL Studio XPS 435T
8gb ram Intel(r) Core(TM) i7 CPU @ 2.67GHz
64-bit OS
Your advice will be greatly appreciated!
Wed, Apr 16, 2014 at 7:19:32 AM | Graphic Cards Issue_Extra lines or materials gone transparent in 3D views
Turn off hardware acceleration under the revit R / options.
Make sure you have the latest video driver installed.
Transparent materials rendered as solid in 3d views?
Thu, Jan 5, 2017 at 8:03:55 AM
Revit 2014 Update 2 crashes constantly on Nvidia Quadro FX 3800 cards [ 1 2 ]
Sun, Sep 20, 2015 at 11:28:23 PM
17
Graphic overrides (phasing) for 3D views
Wed, Apr 30, 2014 at 2:25:42 PM
Walkthrough showing semi transparent lines and surfaces!??
Thu, Aug 15, 2013 at 4:28:33 PM
Transparent object
Tue, Sep 14, 2010 at 1:18:34 PM
Page generation time: 7.1348
