Forums >> Revit Building >> Technical Support >> Element keynote in legend - in 2014
Tue, Apr 15, 2014 at 3:32:36 PM | Element keynote in legend - in 2014
cboersen
I am using Revit 2014.  I have noticed that you can use a "Material" Keynote in a Legend but not an "Element" Keynote.  Is this actually true or am I doing something wrong?
Related to that - any chance that in 2015 we will be able to use tags in legends?
Any work-arounds for these issues?
Tue, Apr 15, 2014 at 3:52:57 PM | Element keynote in legend - in 2014
In both legends and drafting views, you can place detail components and those can be keynoted.  We use an IDF (Invisible detail family that has red crosshairs - sub category line - that is normally turned off and an invisible circle)  (Thanks rkitect)
oh.... and the IDF can be tagged to if you set up one.
Edited on: Tue, Apr 15, 2014 at 3:54:11 PM
Wed, Apr 16, 2014 at 10:44:32 AM | Element keynote in legend - in 2014
cboersen
OK.  I have that working.  I can tag the IDF with a detail tag but how would I get it to accept a wall tag?
Wed, Apr 16, 2014 at 10:54:01 AM | Element keynote in legend - in 2014
You can't use a wall tag.  You need a special tag here that you create.  Try a multicategory ... and you will need a shared parameter in that IDF family for the tag to read.
You can edit your detail tag to create a new one that looks like your wall tag.
Edited on: Wed, Apr 16, 2014 at 10:54:55 AM
Keynote Legend Not Showing Keynote Text
Fri, Sep 6, 2013 at 11:40:59 AM
12
Revit crashes when placing keynote legend
Tue, Jul 25, 2017 at 2:07:43 PM
Keeping an Element Keynote from changing?
Mon, Apr 15, 2013 at 12:14:43 PM
Keynote Legend For Each Detail Sheet
Wed, Oct 3, 2007 at 1:29:24 PM
Material keynote vs Element keynote
Tue, Oct 2, 2012 at 9:26:35 AM
Page generation time: 1.0462
