25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Scope Box in View Schedule
9 Posts No Rating |
Is there any way to show the Scope box in a view schedule?
Phasing is available, why not extents?
Any thoughts are greatly appreciated!
-Marc
just out of intrest:
why would you like to show scop box in the schedule?
9 Posts No Rating |
I am using scope boxes to break up the building into units. Each scope box has a unit name (Unit A, Unit B, etc.).
I would like to use the scope boxes to help me define which unit is being shown in each view. As of now I have another parameter called unit which I have to enter manually.
Does anyone have any thoughts?
You can go to Settings... Project Parameters and add a parameter called "Unit" to doors, windows, rooms, and anything else you want to schedule. Then you go into each schedule and add the Unit field. While in the schedule you can enter the unit names into each door, window, and room. Now you can sort or filter the schedules by Unit.
Post edited on 2006-02-28 12:03:10
Make Scope Box Visible after all Views Hidden |
Tue, Oct 25, 2016 at 4:40:46 PM
Grid Bubbles relative to scope box. |
Tue, Jul 10, 2007 at 4:20:50 PM
Scope Box Datum Control |
Fri, Apr 21, 2006 at 6:57:15 PM
Scope box not visible |
Thu, Oct 19, 2017 at 12:33:04 PM
scope boxes / far clip offset / view range |
Wed, Nov 6, 2019 at 2:11:05 AM
