22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> High Gloss Ceramic Cladding
Hi there,I need to create an extrior finish on my building which will be ceramic cladding, high gloss, black.I created a new wall type and made the outside suface porcelain, black and set the appearance to high gloss. However it just looks like a matt, completely black finish when i render.
I have attatched an image of the kind of finish i want and wondered if somebody could point me in the right direction....?
I'm quite a novice and I'm using Revit 2014.
Many ThanksJess
Tp get the glossy effect you need to have good lighting specified and it must be a 'rendered' view.
You also need to add a "bump" to simulate the tiled appearance.
Instead of starting with a "paint" 'type appearance, insert the porcelain appearance from Revit and modify this (copy as a generic).
See image attached for an example.
Edited on: Tue, Apr 29, 2014 at 5:33:07 AM
Cladding |
Wed, Jun 12, 2013 at 3:01:52 AM
Can Door/Window cut through multiple walls |
Wed, May 26, 2010 at 9:46:05 AM
Cladding |
Mon, Jan 23, 2017 at 3:27:53 PM
Partial height Ceramic Tile |
Thu, Feb 23, 2012 at 9:31:28 AM
Timber cladding with occasional colored panel |
Wed, May 4, 2011 at 9:35:02 AM
