Forums >> Revit Building >> Technical Support >> RAC14: Toposurface below sea level
Mon, Apr 14, 2014 at 7:17:21 AM | RAC14: Toposurface below sea level
ljtaylor88
I've created a toposurface from the surveyor's AutoCAD dwg, all looks good and well with that. I've created a level at 0.0 and named it "Sea Level". The toposurface is below this level, and I can drag it up to roughly meet 0.0 in elevation view, but cannot find a way to move it up the z-axis incrementally (and thus, more accurately for sharing purposes)If I don't move it up, however, the building pad sits at 0.0, which, obviously, doesn't look right.I feel there is a very simple setting I am missing here, but I'm going mad trying to find it. thanks in advance.
Mon, Apr 14, 2014 at 7:49:16 AM | RAC14: Toposurface below sea level
Revit gives you the means to control all of the correctly and the information is all in your HELP.  Read up on Project Base Point vs Survey.  You can also set your levels to either of these settings and swap back and forth.  So you can have first floor set to project at 0'-0" and yet the grade outside might be 986.3' .... Two different base origins that can be controlled independently or together.   Relocate the project is the best means of control but you can do it manually as you have done.
Watch this video:
http://www.youtube.com/watch?v=BigvY4LT-RI
Tue, Apr 15, 2014 at 9:17:39 PM | RAC14: Toposurface below sea level
ljtaylor88
Thank you - the video tutorial was very useful. I've managed to fix it (toposurface is actually a good 100m above sea level in WCS).
A toposurface problem?
Mon, Sep 18, 2006 at 9:16:10 AM
Toposurface Elevation
Mon, Mar 26, 2007 at 8:03:00 AM
topography not being generated at the correct level
Thu, Oct 12, 2017 at 8:01:15 AM
Dual level tag with sea level automatically calculated.
Thu, Nov 29, 2018 at 8:43:50 AM
System Families: Spot Elevation Tag
Thu, Jan 20, 2011 at 7:22:13 AM
Page generation time: 0.2091
