Forums >> Revit Structure >> Technical Support >> Revit 2013, Material Takeoff
Sat, Apr 12, 2014 at 5:37:49 AM | Revit 2013, Material Takeoff
joeinck
Greetings,
Well I created a wall material schedule and it list each length of wall twice?
Any ideas why it does that? pretty simple wall...attached below
thanks
j
Mon, Apr 14, 2014 at 7:33:12 AM | Revit 2013, Material Takeoff
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Nothing is attached.  A wall does have 2 sides, so is it calculating each face?
Tue, Apr 15, 2014 at 9:15:11 AM | Revit 2013, Material Takeoff
joeinck
I will try that attachment again...
I understand your answer but does that make sense...We need to know the LF of a wall type, like Block or 2x4...the measure or distance command gives us this result while working in a view? Hoping that we can get the LF of wall in a take off schedule....i see my file listed in teh files box, hope it works
j
Tue, Apr 15, 2014 at 9:25:30 AM | Revit 2013, Material Takeoff
Walls and materials are different.  The wall length will be listed if you schedule walls but materials as a part of the wall may have two faces depending on the wall description.  A single material wall will take off will take off as you want.
Edited on: Tue, Apr 15, 2014 at 9:25:49 AM
Sat, Apr 19, 2014 at 1:45:07 AM | Revit 2013, Material Takeoff
joeinck
Awesome, thanks...
j
Revit 2013 Material Takeoff area calculation
Wed, Jun 11, 2014 at 10:28:46 AM
Material Takeoff
Mon, Apr 27, 2015 at 7:32:15 AM
Ceiling Material Takeoff
Thu, Feb 15, 2007 at 3:19:57 PM
Material Takeoff issue
Mon, Oct 25, 2010 at 3:48:35 PM
Wall Material Takeoff vs. Wall Quantity Takeoff for material description
Mon, Mar 15, 2010 at 1:57:00 PM
Page generation time: 3.5050
