13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Help with formula needed
8 Posts No Rating |
Hey!
I have been looking around to find an answer to this question with no luck, so any help is appreciated.
I am building a family where I want to be able to have one visibility parameter to be driven by two other parameters.
For the sake of the example lets call the visibility parameter "X" and the other two parameters "A" and "B".
X - is a yes/no parameter and I want it to be "checked" if: A (wich is an integer) = 8, AND B wich is a yes/no parameter is checked.
how do i write this formula?
formulas are new to me and I only learned how to use the simplest strings so far and I'm having troubles grasping how to formulate strings with more than one conditional statement. so any links to a good beginners guide would also be appreciated.
/Stefan
Read this topic in your HELP.
Conditional Statements in Formulas
8 Posts No Rating |
thanks for the reply!
I started to write a reply about how I read that section and a bunch of forumthreads that covered the topic, yet still I turned out too stupid to get it. Then I suddenly realized I was thinking backwards. problem is now solved, thanks!
Array Formula |
Tue, Dec 9, 2008 at 11:11:51 AM
Schedule Parameter formula not showing up [ 1 2 ] |
Thu, Oct 28, 2010 at 4:33:57 PM
23
Beam Family Array Formula Help |
Thu, Oct 23, 2014 at 9:40:34 AM
Using schedule total in formula? |
Fri, Apr 4, 2014 at 10:29:50 AM
One family parameter has formula one has none |
Wed, Jun 25, 2014 at 1:05:54 PM
