Forums >> Revit Building >> Technical Support >> Material color matching
Tue, Apr 8, 2014 at 5:01:40 PM | Material color matching
cw202t
I s there a way to match material (RGB) color numbers to that of a manufacturer like Kelly Moore.
Tue, Apr 8, 2014 at 7:39:00 PM | Material color matching
cw202t
I am trying to match paint chips from Kelly Moore to Pantone colors in Revit so I can get an exact match. For example is there a way to figure out what the RGB of Spanish sand in Kelly Moore would be in Pantone?
Tue, Apr 8, 2014 at 11:42:52 PM | Material color matching
mansell5
3.5 Stars: 4 Votes
hello there, try this link,
http://goffgrafix.com/pantone-rgb-100.php
cheers
geoff
Edited on: Tue, Apr 8, 2014 at 11:44:58 PM
Wed, Apr 9, 2014 at 7:48:48 AM | Material color matching
Be aware that nothing shown on computer screens can really be relied on.  Every screen and printer will show colors differently because there is no really good standard.
But... on one system, you can match the colors on that screen.  They may not print the same as what you see on the screen.
Wed, Apr 9, 2014 at 8:22:47 AM | Material color matching
cw202t
I appreciate the responses. In revit 2014 when selecting the RGB colors there is an Pantone option. I guess what I'm looking for is a cross reference from other paint manufaturors color chips to the Pantone number. So a Benjimen Moore Kelly Green would be what Pantone number.
How do others match color chips exactly in there renderings?
Wed, Apr 9, 2014 at 8:48:12 AM | Material color matching
mansell5
3.5 Stars: 4 Votes
the link i sent you had all the pantone rgb numbers.
all you need is the benjamin moore rgb number.
if there is no match, you cant match with a pantone.
but a near match, so a customised pantone.
Wed, Apr 9, 2014 at 9:22:08 AM | Material color matching
cw202t
thanks Mansell5
I also found http://encycolorpedia.com that will match what looks like every paint makers rgb numbers to any other.
2011 change material color [ 1 2 ]
Sat, Aug 31, 2013 at 8:46:22 AM
16
Matching paint samples with Revit Renderings
Tue, Jun 28, 2016 at 4:23:03 PM
why shading material color gets overridden by surface color
Wed, Apr 25, 2018 at 9:53:40 AM
Material Color Change not Rendering (...but Old one does)
Thu, Mar 6, 2008 at 8:38:56 AM
How to do Cable Tray with Real Material Color (Not just filter color)
Wed, Feb 18, 2015 at 3:14:07 AM
Page generation time: 0.6424
