Forums >> Revit Building >> Technical Support >> Revit Roof+rafting extension
Tue, Apr 8, 2014 at 1:01:58 PM | Revit Roof+rafting extension
viktorik88
Hi to all!
I am triing to make this kind of roof but no succces, base roof is made with no defined slopes but with escalated points and defined split lines ... and the rafter extension doesn't see 2 faces of this roof... I can;t choose this faces to define the workplane for making a beam system the edges a parallel dor this faces Sad
May be this is not the wright way to make it...
revit 2014 file.
Thanks!
Tue, Apr 8, 2014 at 1:35:17 PM | Revit Roof+rafting extension
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Why are you using points instead of slopes?  This is a simple roof and can be done by defining slopes.
Tue, Apr 8, 2014 at 1:56:50 PM | Revit Roof+rafting extension
viktorik88
yes but I need the top to be on a specific height ,slopes will be like 32.38 deg and all various, if i will copy this slopes value to second o roof with slope defined by edges but what if I need to move the top so I will need to redifine the value on all edges.
Tue, Apr 8, 2014 at 2:54:26 PM | Revit Roof+rafting extension
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Is this an existing roof?  Why are the slopes at such an arbitrary angle?
Tue, Apr 8, 2014 at 3:18:46 PM | Revit Roof+rafting extension
viktorik88
yes , existing ant not only, some of faces need to have at the top 1 common point the distences from projections of this point to edges are not the same so angles must be differents... that's ok.
Tue, Apr 8, 2014 at 3:46:48 PM | Revit Roof+rafting extension
viktorik88,
I'm not sure that this applies to your problem ... teafoe is addressing that.  But I wondered if you knew that you can enter almost any numeric field by using an equation rather then possibly a rounded number?  For instance, to enter a roof slope on a roof edge when you know the eave elevation, the peak and the distance horizontally, you can enter =(peak elevation - eave elevation)/distance. (obviously you substitute the numbers)
Adding New Section of Roof to Extension On House
Wed, Sep 2, 2009 at 7:27:03 AM
Roof Overhang extension
Fri, Feb 3, 2017 at 8:20:07 PM
View Title Extension line
Mon, Apr 23, 2007 at 6:38:22 PM
Stair railing at extension in Revit 2012
Wed, Feb 1, 2012 at 12:11:10 PM
Wood Framing Walls Extension Review
Thu, Sep 23, 2010 at 2:51:06 PM
Page generation time: 2.8989
