Forums >> Revit Building >> Technical Support >> Toposurface appears flat in 3D View
Mon, Apr 7, 2014 at 1:42:18 PM | Toposurface appears flat in 3D View
frebeccal
I created a property line and then added the toposurface points of various elevations in the site plan. When I go to the 3D view of the site, the topography is completely flat with only the topography lines showing up. Even when I render the view, my site appears completely flat. (see attached pictures) I am using the Student/Educational Revit 2014. How can I fix this?
130398_testsite.rvt2014-Apr-0711-33-14AM-0003d_1.png130398_site_plan_view_of_topography.png130398_3D_view_of_topography.png
Mon, Apr 7, 2014 at 1:45:30 PM | Toposurface appears flat in 3D View
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Hard to say we don't have enough information from you.  Property lines don't matter.  The only thing that matters is the points elevations.  If you only have a couple inches difference between your lowest point and your highest you aren't going to see a big difference (if at all) when looking at it from far away.  You could test it by putting some points way below or above your other points to make sure you are doing it correctly.
Mon, Apr 7, 2014 at 2:48:17 PM | Toposurface appears flat in 3D View
If you add a section box to the view and it cuts your topo, you will get cut "sides" to your topography with earth hatch and that will help you see the slope.
Tue, Apr 8, 2014 at 9:58:05 AM | Toposurface appears flat in 3D View
mansell5
3.5 Stars: 4 Votes
what are the units of the drawing and is the contour the same units?
i.e. not a decimal point issue when inputting the point levels perhaps?
Tue, Apr 8, 2014 at 7:58:18 PM | Toposurface appears flat in 3D View
frebeccal
All of the units are in feet/inches. The elevation points range from 0" to 10" and the terrain appears completely flat on both the 3D view and the section view (see attached picture) .
Tue, Apr 8, 2014 at 8:15:32 PM | Toposurface appears flat in 3D View
mansell5
3.5 Stars: 4 Votes
how about posting the topo so we can see the level points and values.
we could then duplicate the plan on our computer and see if we get same issue.
Edited on: Tue, Apr 8, 2014 at 8:16:31 PM
Tue, Apr 8, 2014 at 8:26:42 PM | Toposurface appears flat in 3D View
frebeccal
I do not have a specific site for this project, so I do not have specific topography values. I've been using this program for a few months now and made all of my topography in the same way and never had this problem before.
Tue, Apr 8, 2014 at 8:39:39 PM | Toposurface appears flat in 3D View
mansell5
3.5 Stars: 4 Votes
how did you cut a section if you dont have the site?
is it a cad import? all drawn in 2d perhaps
Edited on: Tue, Apr 8, 2014 at 8:40:35 PM
Wed, Apr 9, 2014 at 7:45:45 AM | Toposurface appears flat in 3D View
This is not a problem because Revit is showing you exactly what you have.
First view - plane 3D, second view section box - left on for you to see.
Tue, Nov 7, 2017 at 3:04:47 PM | mansell5
msage
Quoting mansell5 from 2014-04-08 09:58:05
Thanks for this, it was my problem Smile
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
how to view a toposurface with thickness in a elevation ou in a 3d view??
Thu, Jun 16, 2011 at 1:28:29 PM
Large Toposurface and File Size
Fri, Aug 29, 2008 at 10:15:18 AM
Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
Wed, Jun 4, 2014 at 11:10:06 AM
11
Using Survey Data to create a toposurface
Mon, Oct 4, 2010 at 2:23:28 PM
Page generation time: 2.0779
