Forums >> Revit Building >> Technical Support >> Problem witch stair visibility
Sat, Apr 5, 2014 at 1:16:11 PM | Problem witch stair visibility
Jozko
Hallo, I have a big problem stair on one floor level ist not complete.
Please help me what i must doThank you.
Mon, Apr 7, 2014 at 7:03:51 AM | Problem witch stair visibility
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Not enough information.. What is the problem you are having
Mon, Apr 7, 2014 at 5:30:24 PM | Problem witch stair visibility
Jozko
I dont see complete stair on picture 4 it is OK, but on picture 3 it is not complete :/On picture 3 on visible view graphic all on stair is ✓ , but it is not complete.
Sorry I dont have a good english.
Edited on: Mon, Apr 7, 2014 at 5:31:48 PM
Tue, Apr 8, 2014 at 6:53:06 AM | Problem witch stair visibility
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Image 3 is from a different level I assume.  Is your view range set low enough to see the stair?
Tue, Apr 8, 2014 at 4:51:09 PM | Problem witch stair visibility
Jozko
I set default view range. On all levels is the same setting.I dont see all stair :/
Wed, Apr 9, 2014 at 12:41:02 AM | Problem witch stair visibility
vjain
you can check on visiblity graphic setting.
Wed, Apr 9, 2014 at 7:08:58 AM | Problem witch stair visibility
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Set your Bottom and View Depth to Level Below and see if that helps your stair situation.  If you want to see the entire stair you may need to use a Plan Region
Stair visibility issue
Sat, Jan 5, 2013 at 3:19:19 PM
Problem with visibility
Mon, Mar 13, 2006 at 9:17:29 AM
Stair Visibility Issues
Fri, Jun 7, 2013 at 8:58:58 AM
14
Monolithic stair PROBLEM
Sat, Feb 9, 2013 at 8:14:32 AM
Stair Visibility - Revit 2008
Tue, Nov 11, 2008 at 7:42:38 PM
Page generation time: 0.5904
