Forums >> Revit Building >> Technical Support >> Adding mullions to a window
Sun, Feb 26, 2006 at 4:31:19 PM | Adding mullions to a window
phishyman2
I am kinda blown away by how difficult it is to add mullions to a window. I would love to be able to add a 24"x72" fixed or casement window WITH MULLIONS. There does not appear to be anything like this with the default windows or on the Revit site online. I keep looking for a checkbox or setting to add mullions, but for the life of me, cant find one. I have looked at numerous websites for tutorials and forums for people having the same problem as me. It seems to me that having mullions on a window is a common thing. Am I wrong? I feel like I am in the Twilight Zone.
Tue, Feb 28, 2006 at 4:35:49 AM | RE: Adding mullions to a window
eldados
eldados Avatar
4.5 Stars: 8 Votes
you are still here with us... Smile to add a mullion you will need to edit the window family and add it there. you can also make it a yes/no parameter, meaning you can than have tick box you've been looking forSmile might be easier to download a family that has it already. HTH
Integrator
KarelCAD
Tue, May 6, 2008 at 11:47:36 AM | Adding mullions to a window
ccaponigro
 I also find this very frustrating. I do not want to create a new family of windows each time the Architect decides to change the grill pattern. I believe the grill should be a separate family attached to the window and parametric in nature. I am experimenting with face based mullions that would resize when the host window is resized but have not had much luck. If you come up with an acceptable method I would love to hear about it. I am also experimenting with curtain grids which are very cool and if you make the panels blank the can be overlayed on a window and constrained by the window edges but I am having trouble controlling what plane they wind up in.
Mon, Nov 22, 2010 at 10:09:02 AM | Adding mullions to a window
kredman
kredman Avatar
I created a way by nesting a mullion array family into my window sash.  Attached are some examples of it in action.
If there is any interest, I'll post how I did it.
Wed, Feb 2, 2011 at 8:02:44 PM | Adding mullions to a window
jackspellman
Hi Kredman,
I'd be very interested to see how you created your mullion array family.  Please post!
Thu, Feb 3, 2011 at 9:29:28 AM | jackspellman
kredman
kredman Avatar
Quoting jackspellman from 2011-02-02 20:02:44
Hi Kredman,
Sure, I'll post a short tutorial and the rfa sometime soon!
Fri, Nov 25, 2011 at 10:06:09 PM | Adding mullions to a window
CRHDesign
Hi kredman,
Can you post how you did the Muttins? I have tried to duplicate it but can't seem to figure it out. Nice job. Looks simpler comapired to others I run across.
Thx!
Wed, Dec 14, 2016 at 10:02:30 AM | Adding mullions to a window
jtb4
Can you please share your window.
i would like to learn how you created it and how to set up with the muntins....
thanks!
JB
Wed, Dec 14, 2016 at 10:19:19 AM | Adding mullions to a window
Folks, that poster has not been around since 2012.
Download a manufacturer window from Seek that has muttins and examine how it is made.
Adding mullions to an existing window family
Thu, Aug 24, 2006 at 5:22:43 PM
Adding mullions to a fixed or casement window
Mon, Feb 27, 2006 at 1:52:13 PM
Window Mullions
Wed, Nov 29, 2006 at 7:58:12 AM
Window mullions as instance parameters...!
Thu, Jul 31, 2008 at 3:56:04 PM
Arched Window Mullions
Thu, Aug 11, 2005 at 4:23:53 AM
Page generation time: 0.2538
