25 Users Online (23 Members):
Forums >> Workflow & Implementation >> API & Third Party Apps >> 3D pdf converter for Revit LT?
Does anyone know if one exists as I cant establish wehther the most available actually work with Revit LT, the trials dont seem too but then other full version holders have the sam eproblems so without forking out the expense I wondered if anyone knew of one that did in fact work?
many thanks
Tim
PDF's are a print process, not a conversion. They are not provided with Revit, you need a 3D PDF program. Instead, you can create 3D DWF's, that is supported.
I have been told by 3DA systems that there process is not compatible with LT, just wondered if anyone knew of any that were?
Try the 3D PDF Converter Plug-in for Autodesk® Revit today and get it for free |
Thu, Feb 16, 2012 at 10:40:13 PM
PDF - DWG, DWG - PDF |
Mon, Jan 26, 2015 at 11:15:56 PM
REVIT 2012 BATCH CONVERTER |
Thu, Jun 30, 2011 at 4:27:10 PM
Announcing the 3D PDF Converter for Revit Pre-Release Program |
Wed, Dec 7, 2011 at 3:14:26 PM
Current 3d PDF converters? |
Tue, Mar 13, 2018 at 4:33:21 PM
