Forums >> Revit Building >> Technical Support >> Title view
Sun, Feb 26, 2006 at 11:30:31 AM | Title view
carlosgt
When you ceate a sheet and place your different views in the sheet, For every view is assigned a name, (floor plan, Front elevation, etc) Is there any way to change the font size and text stile of these titles? Thanks.
Mon, Feb 27, 2006 at 5:55:17 AM | RE: Title view
puzzle
4 Stars: 10 Votes
Open the titleblock in the family editor Select the title and go to its properties and goto Edit/New "Supplied by arccodex1"
Macca
Sunshine Coast
QLD Australia
Mon, Feb 27, 2006 at 5:52:26 PM | RE: Title view
carlosgt
If I open the title block I am not going to see any of those titles, I am not talking about any text in the sheet, I am talking about the names for the views that you place in the sheet (those that say :"floor plan , 1/4" escale" for example). Is there any way to change this font? I hope you understand this issue. Thanks.
Mon, Feb 27, 2006 at 6:31:48 PM | RE: Title view
arccodex1
3 Stars: 1 Votes
In your project browser go to Families... Annotation Symbols... View Title. Right click on View Title and go to Edit Now you can edit the Type Parameters of each label After you're done load the view title back into your project Post edited on 2006-02-27 18:32:22
Mon, Feb 27, 2006 at 10:12:22 PM | RE: Title view
carlosgt
If I am in my work sheet and go to my browser project to annotations, title view, and right click, the option "make element editable" is not acyive, I tried to go to properties but I can not make any changes here. If I click the titleblock and click "edit" I do not find annotations in the project browser, which is very small. I do not know maybe I am doing something wrong. Can you give a little more tips, Thanks.
Moving View Title
Sat, Mar 6, 2004 at 9:46:28 AM
Modify View Title
Wed, Jun 11, 2014 at 7:37:29 AM
11
Revit View Title with buble on right side
Thu, Mar 11, 2010 at 10:37:28 AM
Control Line in View Title Tag
Mon, Jun 11, 2018 at 7:45:48 AM
View Title for Legends
Fri, May 6, 2016 at 4:27:58 PM
Page generation time: 0.5916
