Forums >> Community >> Newbies >> Need help with Copy/Monitoring
Tue, Apr 1, 2014 at 12:14:57 PM | Need help with Copy/Monitoring
tevan2u
I have a project that Im aboiut to start from scratch and the architect is using Revit 2012 and we have 2014 and we want to Copy/Monitor the walls, can I Copy/Monito using different releases?
Tue, Apr 1, 2014 at 12:30:12 PM | Need help with Copy/Monitoring
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Did you try it?  When you link in a Revit model from a different Release such as 2012 to 2014 it will upgrade the 2013 model to 2014.  You can Copy/Monitor from 2012 to 2014 it appears however everytime you open your 2014 file it will re-upgrade the 2012 linked file which can be very time consuming depending on how big the linked file is.
You posed this question twice so I removed it from the other area.
Edited on: Tue, Apr 1, 2014 at 12:35:33 PM
Tue, Apr 1, 2014 at 12:50:59 PM | Need help with Copy/Monitoring
tevan2u
Well thanks that helps, and yea I'm sitting here waiting for it to upgrade it and its been like almost 15 minutes.
Tue, Apr 1, 2014 at 12:54:53 PM | Need help with Copy/Monitoring
If you are going to link in a lower year revit model, always upgrade that first and save it to your project file.
However, I'm not sure with any changes made to the monitored file.  It may be you lose the monitor link.  This is wht all parties should be on the same revit release.... established ahead of time before doing any work at all.
THINK AHEAD!
Copy Monitoring Walls - Downspouts
Fri, Feb 28, 2014 at 9:27:42 AM
Errors when Copy/Monitoring Levels
Tue, Jan 30, 2018 at 4:27:02 PM
Copy/Monitor Deleted Element Revit 2011
Sun, Aug 14, 2011 at 6:09:41 PM
Errors while trying to Copy Monitor
Wed, Nov 15, 2006 at 8:55:06 AM
Copy/Monitoring Arch Walls Help !!
Sat, Jun 22, 2013 at 11:02:36 AM
Page generation time: 0.5012
