Forums >> Revit Building >> Technical Support >> Wall with temp. glass
Sun, Feb 26, 2006 at 11:08:05 AM | Wall with temp. glass
carlosgt
Does anybody knows how to create a wall in a shower (42" high with temp. glass enclosure) in a floor plan? Is it necessary to create it in 3D just to show it in floor plan? What we used to do in CAD is draw a line in the middle of the wall, and that would be the glass. I noticed that I can not do the same in Revit, It does not allow me to draw lines in the walls. Is there any trick that I can use? I do not want to build the whole component beacause I do not think we are going to use it for a section. Thanks.
Mon, Feb 27, 2006 at 5:59:51 AM | RE: Wall with temp. glass
puzzle
4 Stars: 10 Votes
If you don't want to build it you could add a filled region to the wall and then add lines to represent the glass or simply extrude a wall with glass as the material. I have recently done this for a shop fitout.
Macca
Sunshine Coast
QLD Australia
Glass Wall Join Issue
Thu, Apr 10, 2008 at 11:15:38 AM
not enough space on temp for rendering
Wed, Feb 9, 2011 at 6:03:49 AM
How to change glass wall to a frosted design?
Wed, Dec 15, 2010 at 5:52:33 PM
Glass Block Wall
Wed, Apr 20, 2005 at 12:04:41 AM
Temp Dim's are too small
Mon, Jul 30, 2007 at 10:36:05 PM
Page generation time: 0.5652
