Forums >> General Discussion >> Revit Project Management >> Spot elevation Tag and Insulation
Mon, Mar 31, 2014 at 1:36:51 PM | Spot elevation Tag and Insulation
Pikachu123
Hey Revit Guru's, is there anyway possible for the spot elevation tag, reading bottom of pipe to ignore insulation thickness? because we are in the position of using bottom of pipe on our elevations, and now i'm having to remove the insulation then place the spot elevation, and put back on the insulation, or else the spot elevation reads to the bottom of insulation, not pipe, quite the pain if i may say. Any input would be greatly appreciated. please and thank you.
Mon, Mar 31, 2014 at 1:41:54 PM | Spot elevation Tag and Insulation
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
If you hover over the pipe you should be able to hit the tab button to select what you want your tag to read
Wed, Jun 11, 2014 at 10:00:27 AM | Spot elevation Tag and Insulation
Pikachu123
Thank you kind sir that helps huge instead of moding a template every view switch, then remembering to switch it back, appreciate that tid bit. i knew about the tab command, but sometimes stuff just doesn't click when you want it too. =).
Spot Elevation tag
Tue, May 6, 2014 at 12:41:09 PM
Invert Elevation Vs. Spot Elevation
Mon, Apr 20, 2015 at 2:09:11 PM
Spot elevation tag issue
Mon, Jun 3, 2019 at 3:18:37 PM
ceiling tag to read as spot elevation (top or bottom elevation) (2017)
Tue, Aug 28, 2018 at 10:51:10 AM
System Families: Spot Elevation Tag
Thu, Jan 20, 2011 at 7:22:13 AM
Page generation time: 1.9041
