15 Users Online (13 Members):
Forums >> Revit Systems >> Technical Support >> Electrical Clearance
good afternoon. i'm using Revit 2014, and have an issue with clearances. the project that i'm working on, i'm modeling the Electrical as part of a coordinated effort. i have taken the items (VFD's, Panels, Light Fixtures...etc.) and added a clearance to them. i created a new subcatagory in the family for Electrical clearance, and have it working in revit. it looks right, and i can strech them up and down to the floor and ceiling. when i export the 3d view to either .dwg, or .nwc it makes the equipment, or light fixture, and the clearance into one item with only 1 layer. the BIM coordinator for the project wants to see it in .dwg with a seperate layer for the clearance, so that he can have visibility control to make the clearance semi-transparent and the item solid. i have looked, and can't figure out what is going wrong. any ideas?
Try to learn at least one new thing every day |
Vinny - I don't do MEP but I think your problem is category..... What if you make this item a sperate nested family in a different category. You could run a quick test by loading a simple family into yours ... doesn't have to be correct for the test.
thanks i'll give that a try.
i still don't know what i'm doing wrong. i started with a Electrical Equipment family model. i then inserted a Electrical Devices family item into it. then i loaded that into my model and exported that to .dwg. it still only has the electrical equipment layer in autocad.
Was the nested family shared?
i don't think so.... do i need to use shared parameters to make this work. i don't have much experience using them.
here is the family that i'm using. please take a look at it and see what i missed. i looks and works great in Revit, but only has one layer in Autocad. can i adjust how it exports to Autocad?
Vinny
Change your cad export setup.
By George, that worked.. thank you so much. i knew it had to be a simple fix. but i was racking my brain on it.
modeling electrical clearance |
Thu, Mar 13, 2014 at 1:04:32 PM
Cable Tray Clearance |
Mon, Mar 24, 2014 at 10:44:48 AM
ADA door clearance |
Thu, Jun 8, 2006 at 10:23:53 PM
Ceiling No-Fly/Clearance Zones |
Mon, Sep 12, 2016 at 12:02:59 PM
Fri, Jun 14, 2019 at 5:48:11 PM
