Forums >> Revit Building >> Technical Support >> cant show a floor slope in linked file in revit
Mon, Mar 31, 2014 at 9:45:17 AM | cant show a floor slope in linked file in revit
jsel13
has anyone had trouble showing a floor spot slope in linked file? for some reason i cant get it to register the floor slope
Mon, Mar 31, 2014 at 10:04:43 AM | cant show a floor slope in linked file in revit
Most tags will not work with linked objects.  It appears that slopes is one of them.... I just proofed your problem.
But.... if you copy/monitor the floor, then you can use the spot slope.
Mon, Mar 31, 2014 at 10:26:35 AM | cant show a floor slope in linked file in revit
jsel13
i've been using revit for years and never actually tried using copy monitor. will that allow me to show floor slopes?
How to swicth between levels with a linked revit file
Thu, Feb 18, 2010 at 7:43:39 AM
Typical Floor as a Linked Revit File
Fri, Aug 11, 2006 at 10:35:25 AM
Floor drain slopes adding lines to the slope when modifying sub elements
Tue, Oct 16, 2012 at 3:55:57 PM
STAIRS IN LINKED FILE WON'T SHOW UP IN MAIN CENTRAL FILE 3D
Mon, Jun 25, 2012 at 3:58:52 PM
Floor with Valleys and Ridges - Hosted Components Won't Slope
Thu, Oct 28, 2010 at 2:01:36 PM
Page generation time: 1.9186
