Forums >> Revit Building >> Technical Support >> Reference sheet conflict!
Mon, Mar 31, 2014 at 7:46:33 AM | Reference sheet conflict!
neomaxmaya
5 Stars: 2 Votes
Hi all,
When creating a new viewport (not a duplicate) Revit is referencing it to another sheet/viewport that is not relevant at all!
The logic with Revit about back referencing is it will reference the oldest parent view. Thats fine. but when im creating a new floor plan view with no parents at all, why revit is still referencing another sheet???
 Thanks all.
"Im using Revit2013"
Edited on: Mon, Mar 31, 2014 at 7:47:56 AM
Mon, Mar 31, 2014 at 7:54:57 AM | Reference sheet conflict!
We don't know how you created your view.  Did you use the view tab / ceiling plan?
Mon, Mar 31, 2014 at 8:04:38 AM | Reference sheet conflict!
neomaxmaya
5 Stars: 2 Votes
Yes my friend, by the view tab / ceiling plan.
Mon, Mar 31, 2014 at 8:07:25 AM | Reference sheet conflict!
Well my friend, you fail to tell us what Revit and what updates you have installed.  Look there first.
Mon, Mar 31, 2014 at 8:17:35 AM | Reference sheet conflict!
neomaxmaya
5 Stars: 2 Votes
Its 2013 with no updates.
Do you suggest to update the vesion?
Mon, Mar 31, 2014 at 8:22:58 AM | Reference sheet conflict!
What do you think?  They create updates to correct program malfunction.
I believe 2013 has 3 updates and they all have to be installed ...in order.
Mon, Mar 31, 2014 at 8:23:38 AM | Reference sheet conflict!
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"Do you suggest to update the vesion?"
You ALWAYS want to installe the updates, they fix problems that were found after the release date.  I believe there were 3 updates for 2013, you will need to install them all in order.. 1, 2 then 3
WWHub got it first, guess I type to slow!
Edited on: Mon, Mar 31, 2014 at 8:24:30 AM
Mon, Mar 31, 2014 at 8:26:01 AM | Reference sheet conflict!
neomaxmaya
5 Stars: 2 Votes
Thanks all!
Showing wrong reference sheet on view title
Wed, Oct 17, 2018 at 12:26:30 AM
14
Section title line showing wrong reference sheet
Thu, May 5, 2011 at 11:02:24 AM
option Conflict
Tue, May 29, 2007 at 11:22:17 AM
Can titleblock scale only reference one of many views on the sheet?
Sun, Apr 14, 2013 at 10:46:46 PM
Reference tag on on same view?
Wed, May 2, 2018 at 11:25:28 AM
Page generation time: 0.2461
