Forums >> General Discussion >> Revit Project Management >> Why won't my mullions show above the base plane
Sat, Mar 29, 2014 at 1:07:22 PM | Why won't my mullions show above the base plane
neonenvy
I had a simple curtain wall (storefront) and I edited the profile to go in a zig zag motion across mutiple floors, I can only see the glass on the upper levels and no mullion.
I also made a curtain wall and had its top constraint go to level 3 for another curtain wall in the project, but still no mullion I can view for the second level.
Anyone know a fix. nothing is hidden in the visibility and graphics section. Im tempted to say it could be fixed in the view range, but last time I touched it my revit got messed up so i'm kinda afraid. I rebooted my computer for another issue so everything is now at factory settings.
Any advise? Thanks!
Mon, Mar 31, 2014 at 8:26:42 AM | Why won't my mullions show above the base plane
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Do you actually have mullions applied to the curtain wall?  Do they show up in 3D?
Mon, Mar 31, 2014 at 8:35:16 AM | Why won't my mullions show above the base plane
".....I edited the profile to go in a zig zag motion across mutiple floors...."  Not sure what this means - an image would have helped.
Is this what Revit?
Do you have an applied view template?
Are you using design options?
The 3D Teafoe asked for should help us.
Curtain wall vertical mullions won't go vertical
Mon, Apr 15, 2013 at 6:19:36 AM
12
Wall won't show in North elevation
Thu, Oct 9, 2014 at 12:21:15 PM
Mullions won't render
Wed, Jun 24, 2009 at 4:09:30 PM
Hatch Pattern in GYP ceiling won't show
Thu, Mar 12, 2009 at 10:00:42 AM
14
Elevation won't show in preview and can't be printed out
Fri, Nov 20, 2015 at 10:58:59 AM
Page generation time: 1.6430
