Forums >> Revit Building >> Technical Support >> Dimensioning to angled wall joins
Wed, Jun 16, 2004 at 4:35:32 PM | Dimensioning to angled wall joins
FineDesignz
How do you precisely locate a 45 degree corner? When I use a horizontal dimension to the corner, it's not editable... Thanks!
Michael W. Smith Fine Designz
Wed, Jun 16, 2004 at 6:01:17 PM | RE: Dimensioning to angled wall joins
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you are unable to edit the dimensions, try placing some temporary intersecting lines in the position you want to place the wall corner. Once you have that location move the walls corner to the intersection of these two lines.
Thu, Jun 17, 2004 at 7:16:43 AM | RE: Dimensioning to angled wall joins
Bimman
Bimman Avatar
1 Stars: 2 Votes
i know that in 6 anad 6.1when you glide over the angle joint a solid box appears and that is you dimension point. try geting in closer tha may make a difference. i am not sure about other versions whether they do this or not.
Thu, Jun 17, 2004 at 11:22:44 AM | RE: Dimensioning to angled wall joins
FineDesignz
Yes, I have 6.1. But the only points are located at exterior/interior faces of the walls, no matter which type of wall join you use. And the dimensions are not editable.
Fri, Jun 18, 2004 at 9:55:34 AM | RE: Dimensioning to angled wall joins
melarch
You certianly can dimension to angled wall positions. if you want to dimension between two angle walls, select the dimension tool and place your cursor over the first angle wall position and press teh tab key until you get the desired grip point anywhere within a walls layers of sub-components. Repeat this for teh other end to get the second grip point on an angled wall. This will work with any walls and any location within a walls layers or components.
Mel Persin, Architect-AIA
Fri, Jun 18, 2004 at 10:41:27 AM | RE: Dimensioning to angled wall joins
FineDesignz
Thanks for the reply, but I'm not dimensioning BETWEEN two angled walls. I wanted to run a horizontal builiding dimension and catch the corners of angled wall joins; such as you would dimension to a 45 degree bay popout in a breakfast nook. In this type of situation, I have found that you can only dimension to the wall face (either side), not to the core of the join. And even dimensioning to the face, the angled wall cannot be moved by editing the dimension. If you have found otherwise in THIS case, please let me know... I would love to know how to get this to work. I usually dimension my angled walls with horizontal & vertical dimensions to the points, not with an angled dimension.
Fri, Jun 18, 2004 at 12:10:00 PM | RE: Dimensioning to angled wall joins
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I have had the same issue you are describing... and the work-around that I've found works best is Mr Spot's suggestion.
Hiroshi Jacobs
The Catholic University of America
Wed, Jan 14, 2009 at 6:59:44 PM | Dimensioning to angled wall joins
quinn
Dont forget you can use trim tool.  If you set up reference lines create the angled wall on the line you need then trim the walls they will line up on the reference lines and meet where you want them too the only thing that will change is the dimension but if you check it the walls remain the right length.
Does anyone else wish that there was a toggle to make wall joins the default off
Wed, Aug 19, 2009 at 9:49:42 AM
Can you make wall joins Miter by Default?
Wed, Dec 21, 2016 at 1:52:44 PM
14
Wall joins in linked files
Mon, Aug 19, 2013 at 2:58:42 PM
I hate the Revit Automatic Wall joins
Thu, Oct 25, 2007 at 9:59:44 AM
wall joins
Thu, Oct 20, 2011 at 4:37:14 PM
Page generation time: 1.8323
