Forums >> Revit Building >> Technical Support >> Manufacturer's Window Family with text file
Fri, Mar 28, 2014 at 10:10:05 AM | Linking a Text file with Parametic Family for 50 family types
Polar
I have a text file from Marvin and a revit family file from marvin.
when you open the revit family of the window, only one window size is available as a type, BUT when you open the text file, it lists all kinds of different sizes - here a small sampling....
'CUDH1612,2W,42.75,32.375,DOUBLE HUNG,ALUMINUM CLAD,LOW E II w/argon,2,2,TBDCUDH1614,2W,42.75,36.375,DOUBLE HUNG,ALUMINUM CLAD,LOW E II w/argon,2,2,TBDCUDH1616,2W,42.75,40.375,DOUBLE HUNG,ALUMINUM CLAD,LOW E II w/argon,2,2,TBD'
and there's a header to the text file too:
',Quantity##other##,Width##length##inches,Height##length##inches,Window Type##other##,Frame Type##other##,Glass Type##other##,Number of Lights Wide##other##,Number of Lights High##other##,Design Pressure##other##'
My question is:
Where do I need to put the text file - AND - how to I tell the revit family where it is, so that it can load the other parameters for the different window sizes.
Thanks
Edited on: Fri, Mar 28, 2014 at 10:19:41 AM
think it - build it
Fri, Mar 28, 2014 at 10:22:19 AM | Manufacturer's Window Family with text file
These are type catalogs.  Read this HELP topic
Loading a Family with a Type Catalog
Fri, Mar 28, 2014 at 10:31:58 AM | Manufacturer's Window Family with text file
Polar
Thanks for the help WWHub, I'll read the help topic.
think it - build it
Change Identity Data on Manufacturer Family
Thu, Mar 14, 2013 at 2:33:14 PM
Window's dimension don't show up in the window schedule
Fri, Aug 17, 2012 at 1:34:43 PM
Adding mullions to an existing window family
Thu, Aug 24, 2006 at 5:22:43 PM
NEW WINDOW FAMILY
Tue, Sep 13, 2005 at 6:03:19 PM
Scale Manufacturer's Drawings
Mon, Jan 29, 2007 at 3:41:40 PM
Page generation time: 5.2654
